Which bearing/IM
kenped8
Which bearing/IM
Post by kenped8 »
Which release-bearing did you use for your klze engine with k8 tranny?. The 626 release-bearing is 2mm shorter than the k8 one. Can i use the one from 626? And are the runners on the 626 IM just as big as the ones on the klze, or will i have some power loss?
Klze,CAI,Exedy clutch, HM Engine mounts, HM ss exhaust system,Cobra lowering springs, 18" wheels.
PATDIESEL
Re: Which bearing/IM
Post by PATDIESEL »
The runners are slightly smaller on the 626 then the ZE, probably not much loos though. As for the bearing :shrug:
kenped8
Post by kenped8 »
That`s what i also thought about the 626 IM. It`s the only one i can get here in europe that is bigger than the k8, so i will have to go with that one. Did anybody have the "problem" about bearing?
IanL
Post by IanL »
Is this release bearing you're asking about the Clutch Release Bearing (Throwout Bearing)? Because I've just checked the Parts List and the same part, Collar Clutch Release LF01-16-510, is used in the MX-3, the MX-6 and the 626.
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system :)
