MSD Distributor Cap
MSD Distributor Cap
Hey, I have a 92 GS with a MSD 6AL installed. Now I followed Jeff's directions regarding the install. But the part I'm having trouble with is the drilling of the distributor cap and epoxying the connection. Because of the temperatures where I live, after 2-3 months the epoxy hardens and cracks. I've had to redo this 3 times already.
Now I know the more popular cars have an MSD cap specially made with the connection (Civic). But does anyone know if MSD makes a cap that we can adapt to our car. I searched for an MX-6 or Probe but couldn't find anything. If anyone knows of any other options or can give me suggestions I'd appreciate.
Thanks.
Thanks.
2005 Mitsubishi Lancer Evolution VIII
12.21@114
Yeah it's stock...
12.21@114
Yeah it's stock...
Re: MSD Distributor Cap
Just an idea - could you use the compound that they use to fill the engine mounts? You're just trying to hold it in place and keep moisture out - might be good enough for that?
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system![Smile :)](./images/smilies/icon_smile.gif)
- babyblueMX3
there's no cap made for our car...Originally posted by custom101:
Thanks.
RIP 400whp ZE-T MX-3
I've always wondered if the klze distributer would work. It's got the external coil hook up. Anyone done it?
My Cardomain site
My Cardomain site
- papa roached
good luck finding a new cap for it when it comes time to change it
- goldsberry1
i use a little bit of silicone just to protect it. i've never had trouble with it
92' mx-3 gsr, built engine, forged internals, p/p ze heads. t3/t4e .63/.60 turbo, udp, msd ignition, millenia s injectors, millenia im, water cooled intercooler, afpr, fmu. running at 7 psi right now
Nobody makes one???
http://www.probesport.com/mdc04.html
<small>[ July 02, 2004, 11:45 AM: Message edited by: TsiMiata ]</small>
91 Eagle Talon Tsi AWD *RIP*
- babyblueMX3
does the disty cap of the probe fits on our disty??
<small>[ July 02, 2004, 11:52 AM: Message edited by: babyblueMX3 ]</small>
Not at all. There are tons of guys like me who don't have msd or any sort of ignition upgrade who have a klze disty cap laying around. Especially on probetalk. Lastly, very, very rarely should anyone have to replace their disty cap.Originally posted by papa roached:
Edit: Yes the disty for the probe will fit our car since it is the same one.
<small>[ July 02, 2004, 12:37 PM: Message edited by: mx3man83 ]</small>
My Cardomain site
My Cardomain site
Oh that's awesome!!! Thanks a lot. I searched probetalk too, surprised I didn't find it. Anyway, I just placed my order.
Thanks again!
Thanks again!
12.21@114
Yeah it's stock...
12.21@114
Yeah it's stock...
- babyblueMX3
so if the disty is the EXACT same do that means the wiring is also the same and we can use a msd set-up diagram from a probe..Originally posted by mx3man83:
i always tought they were different
