Hi,
just picked up a 92 gs yesterday and my first problem to tackle is sunroof. I got it all apart and it seems its either that last little gear that spins the 2 rods is stipped, or else the rods might be. The roof would open up and when it got to either end would click like mad. Any adivce from someone whos had the problem would be apprecitaed. Thanks, Sam
Sunroof/Moonroof help please
Sublime68-96
- PATDIESEL
Re: Sunroof/Moonroof help please
They all do that when you try to make it go past its end point.
Sublime68-96
It does that before it gets to the end.
It may be that it is encountering high resistance to motion. Can you wind it right to the end with an allen key in the motor shaft?
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system
Sublime: you need to clean first and then lube the "metalspirals" thats pushing and pulling the sunroof... theyre positioned in the aluminiumrails in both sides
1992 MX-3 V6 Z1 Arbet VIII 17 x 8" -35mm Proracing Springs on KYB Sports, Corksport Strutbars, Brembo Cross Drilled & Slotted, Goodridge SS Brakelines, Corksport SS Clutchline, Mazdaspeed Enginemounts & Front arm bushings, All SRD bushings in shifterlinkage and cross member, Pacesetter Shortshifter, KN Conefilter, Custom SS Exhaust, Stereo Oldschool Goodies Denon & Phoenix Gold, Boston Pro & Cerwin Vega and lots of other small goodies
Hey i found it for ya,it was actualy one of my first posts or replys i ever made on this board i think
http://www.mx-3.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=1;t=003064
Sublime68-96
thanks, ill go try that out tommorow
