how much power can be made from the K8? i get razzed at the part store about having a 1.8L V6 so i want to know how much power can i make out of the engine? is 300+whp possable from the engine?
not gonna happen man, i think you might able to get like 200-250 HP from it with some serious turbo love
Parts needing installed: turbo kit from BB (if i ever get it), 9.0:1 CR Diamond pistons, 4340 forged H beam rods, C/J-Spec spoiler, Nissan red tops in KL rails http://www.cardomain.com/id/blazejeremy
actually you COULD get about 450-500 at the engine before you have to worry about the stock crank.
Yes, I AM a bastard
Here is my web site, I made this last year but didnt feel like shareing it untill now. http://members.rogers.com/curts-klze/
Anything is possible it just takes $$. Put some rods, pistons, turbo and all the other things that go with it in there 25psi of boost and you might make it. Figure it would cost you $10-$15k.
200whp is gonna be very fast, 500hp, youll pee your pants if youd drive car with 500hp, youll be lucky if you come out of it alive lol, want 500hp get muscle car
Magnum s/s lines, strut bars, carbon fiber bezel, indiglow gauge, Sony Xplod, inverted c/f hood, SRD lower tie bar '93 GS SE '95 Cobra SVT #2722 '68 Charger R/T 440 http://www.cardomain.com/id/mitmaks
