does anyone know the weight of a KL-DE or KL-ZE motor, is it enough that a few guys can move it around by hand? im going to get my ZE in a week or two so yea
<small>[ June 01, 2004, 07:36 PM: Message edited by: papa roached ]</small>
KL motor queston
- papa roached
KL motor queston
Re: KL motor queston
About 3-4 decent sized guys can move it no problem. Thats what me and my friends did with my DE.
1993 Mazda RX-7 Touring Edition Innocent Blue Mica- Not stock...
1993 Teal MX-3 GS- KLZE and other goodies. RIP
i can pick it up on my own so its only in the 300-400lb range so yes 3 guys should be able to but i recommend a crane or a crate and drag the crate
god damn man... ur a tankOriginally posted by DavidOS:
-Damian
***if u know of/have a mx-3 GS with a blown engine and live around me... let me know ***
When you go pick it up make sure you tell them that you want it left on a pallet, that way it makes it easier to grab on too. After that three people shjould be able to lift it with ease, im sure the engine is probably only a round a few hundred pounds.
1993 GSR - Black with CS Mazdaspeed style front and sides skirts, KLDE and a bunch of other mods. Patiently awaiting a T3Super60, intercooler,MSnS and a custom fuel rail.
1993 VW Corrado SLC- completely stock. (May she R.I.P)
- Zoso124
Someone weighed one before, can't remember what is was though, without tranny I'd say no more then 250lbs.
Mike Evans
Gone:
Gone:
