Ok i replaced the fuel filter, spark plugs, plug wires, distributor cap, and distributor button. It ran great for a while but now it is starting to do it again. I replaced the wires twice to see if it was a bad set of wires but it is still running bad. It is not the air hoses they are all good. Any other reasons it might be doing this? What it is doing exactly is when i and on the gas the car starts to jump (you know like when you pump the gas) and the rpms jump up and down. Any help would be greatly appreciated. Ok another thing it is doing is when it is just sitting still it idols hard i can feel the car shake.
<small>[ April 26, 2004, 08:21 PM: Message edited by: Ricksmx3 ]</small>
Sputtering Again?
- Ricksmx3
Sputtering Again?
2010 MazdaSpeed 3
- Ricksmx3
Re: Sputtering Again?
I was also wondering if i can take it to a shop and have them hook it up and see what the problem is. The reason i am asking is because it is a 92 and is it to old to have that done?
2010 MazdaSpeed 3
You can take it to a shop, they have a diagnostic tool they can hook up and grab codes.
93 GS, KLZE, KL31 ECU, Centerforce Stg 3 Clutch, 2.25" Exhaust w/Flowmaster muffler, OBX Headers, Pheno Spacers, Front & rear X-drilled/slotted Rotors, KVR pads, SS brake & clutch lines, Ractive Filter, H&R Springs, Tokico Blue Struts, 8mm Accel Wires, MSD 6A w/ Blaster 2 Coil, HVAC Indiglo Panel. *Sold*
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
TPS sensor may be adjusted wrong , also there is a little screw on the throttle body try minory adjusting both of these but make sure you make a mark where they were just in case its not that ..
Kris
Kris
93 Kandy Tangerine Mx3 GS-DE
02 Subaru Impreza OBS
& Lots of Toys to haul
Id guess the TPS. They are a PIA get adjusted. I've been playing with mine for a week. None of the adjustment procedures seem to work all that well and it becomes trial and error of what works best for your car.
91 Eagle Talon Tsi AWD *RIP*
I am too having that same problem with my car. Took it to get it checked for codes they said they didnt find anything and it didnt die. My car could sit and idle for a long time but it seemed like once you started to drive it would sputter out and die.
1993 Mazda Mx-3 GS-Sold
1992 GS "The Bucket" Gone.
92 GS 5spd for sale! Sold it....after I got a hatch cover in great condition
MY WORKLOG, check it out viewtopic.php?f=46&t=79959
- Ricksmx3
Ok it hasent really been running real bad here lately but when i am idoling and i hit the gas you can hear it go putt putt putt real fast and then it accelerates. It is kind of hard to explain. I am also getting a big loss of power. My car is probly a 18 sec 1/4 mie now. That is just to show you how slow it got.
<small>[ May 04, 2004, 08:54 PM: Message edited by: Ricksmx3 ]</small>
2010 MazdaSpeed 3
