Tach Issue with MSD setup
Hey Everyone,
I just recently installed the MSD 6A and Blaster 2 coil and used the 3055 NPN Transistor and 1K Ohm resistor setup. Now of course the Tach doesn't function past 4000rpm. Has anyone found a successful way to fix this? I've searched but no seems to have posted a solution but yet there are still MX-3s that have had this fixed. Do I need to get a MSD tach adaptor and if so does it get it's source from the MSD box or the Transistor?
Re: Tach Issue with MSD setup
I don't know if this is even possible, but I wonder if theres a way to wire the stock tach to the coil when using the msd. Any thoughts??? Just a shot in the dark since I'm not sure how it's wired in the first place on mx3's.
92 GS
'Stock'...
'Stock'...
Hrmm...what kind of 1k ohm resistor are you using? i think ur supposed tou se the 1 amp versions, something about the 1/2 amp ones not working right.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
Yeah, same thing happened to me... you have to buy a tach adapter from MSD. There's two or three different part #s, so ask for the one made for a 1993+ Probe V6. It's solid red and shaped somewhat like the profile of a bell. It's really easy to install.
Manny
Los Angeles
1992 MX-3 GS 2.5L V6
Los Angeles
Do you mean 1/2 Watt. Yes I used a 1K Ohm 1/2 Watt Resistor. That's very strange because the Wattage rating just affects it's current capacity. It doesn't change the resistance value. I've heard that a 1/4 Watt or higher was suggested.Originally posted by Gro Harlem:
Did you run the Tach Adaptor off the MSD Box or the center transistor lead?Originally posted by ma24691:
...you have to buy a tach adapter from MSD... It's really easy to install.
- wyldside
Try and run it off of the MSD Box Tachometer Terminal. That should do the trick.Originally posted by vamperism:
James Gosteli
X-Prez of MX-West
1992 Seal-Gray MX-3 GSR-ZE (KLZE 2.5L V6)
1992 White MX-3 GSR-ZE (KLZE 2.5L V6) Worklog (Parting out)
1993 Blaze Red MX-3 GS - RIP
X-Prez of MX-West
The Adaptor has a red wire and a white one.Originally posted by vamperism:
You'll have to splice in to the skinny red wire and skinny white wire from the MSD box.
So, from the MSD Box:
Skinny red wire splits 2 ways to:
1)red wire on adapter
2)new wire that will lead towards distributor
according to Jeff Abrams' site.
Skinny white wire splits 2 ways to:
1)white wire on adapter
2)the other new wire that leads towards
distributor according to Jeff Abrams' site.
Hope that helps. Sorry for the delay.
Manny
Los Angeles
Los Angeles
