Rad Removal
Rad Removal
Now that we dont' have an online shop manual. I need some directions on getting the rad and fans out.. Where should I begin.
Turbo 2.5l mx3
Re: Rad Removal
Its not that hard, drain the fluid, and then remove rad support unbolt the fans from the rad, unplug them, remove them, then unbolt rad from underneath and remove rad.... Just make sure to get all the bolts, and make sure not to crack the damn plastic endtanks.
Mods:
- ZE, Mike seli 214 intake cams, Ported n polished heads, Interprep valve springs, DE retainers, rebuilt bottom end, toga main and rod bearings, toga hv oil pump, CZT 67mm tb, mbx udp, ported intake mani, SS headers, 2.5inch full exhaust, racingbeat muffler, highflow cat, megasquirt v2.
new toy, 86 TII rx7, JDM S5 motor/turbo, + alot of other goodies
