Does anyone have the OBD codes for the the brakes. I need to diagnose the ABS brakes on my GS. Light keeps coming on a few minutes after driving.
Thanks, Mike
OBD Brake Codes
Re: OBD Brake Codes
Chilterns for MX-6/626/Probe V6 gives some codes for 93-98. To read the codes, connect between FBS and GND in the diagnostic connector, then ignition on, engine off. It's a bit confusing because it talks about watching the number of sweeps on an analogue voltmeter, AND that the light will flash long periods for the first digit, followed by short periods for the second digit. If it does that why bother with the voltmeter?
Anyway, there are 15 codes given (but it implies there are more). If you want them, PM me your email and I'll send you a scan.
<small>[ March 29, 2004, 01:52 AM: Message edited by: IanL ]</small>
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system
Re: OBD Brake Codes
Ian,Originally posted by IanL:
Is that the TBS or the FBS? I have found some information but they refer to jumping the TBS and GND.
Thanks, Mike
