well i got all the connections on the s-afc 2 connected and working, but it seems kina complicated to tune. i was wondering if anyone out there would have some settings on there setup to share.
thanks
Apexi s-afc 2 on klze
Re: Apexi s-afc 2 on klze
Without an A/F meter or EGT setting the s/afc it´s really hard to tune. You should tune it by ear, which is quite innaccurate.
European Mx3 GsRT
I think using the TPS for load sensing is what makes them so hard to tune. I personally think they work a whole lot better using a MAP sensor for load sensing. IF you do a search on google you should come up with some good reading.
91 Eagle Talon Tsi AWD *RIP*
