08 Engine code
08 Engine code
I pulled the engine codes. I got 8 short flashes and one long flash than 8 more short flashes. I take it that the 1 long flash was a separator code. What is my next move? All help greatly appreciated.
Re: 08 Engine code
No, you got 2 Error-Codes:
08 AND 10, 08 is Air flow sensor
10 is Intake Air teperature sensor.
Sounds like the connector is not hooked up
or your air intake sensor is completly
damaged.
Greets
TK
damaged.
Greets
TK
Re: 08 Engine code
If any malfunction has been detected, the light will blink the first digits of the code at long intervals and then blink the second digit of the code at short intervals.
8 is the Mass Airflow Sensor or Circuit (MAF)
The Intake Air Temperature sensor or Circuit (IAT)is actually 11 not 10 so im not too sure what went on there, ToyK sounds right.
Good luck
<small>[ March 25, 2004, 04:21 PM: Message edited by: MikeUK ]</small>
Good luck
Re: 08 Engine code
Thanks for the information. I will check the connector this weekend.
