more odd noises...
reSa
more odd noises...
Post by reSa »
someone please tell me they know what's goin on with my car :D j/k
Nottahonda
Re: more odd noises...
Post by Nottahonda »
Is it when you're stopping in a straight path, or when you are breaking while turning
Casey Guthrie
[email]goesfast@theraces.com" target="_blank[/email]
johnnyb
Post by johnnyb »
could be your calipers are seized and one of the pads is shaking around in there. that may cause a ticking noise while braking but im not sure
reSa
Post by reSa »
it happens when im braking going straight. im pretty sure it's not my cv boots or joints or anything. it's only when i STOP the car. right before i come to a stop
IanL
Post by IanL »
Sounds like suspension wind-up. Could be the stabiliser bushings - they make a ticking sound when they're worn, but usually it's on sharp turns under acceleration - if it does that, too, they'd be worth a look.
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system :)
reSa
Post by reSa »
seems to be getting worse. when i took the car to a mechanic though he couldn't get it to make the noise. so i took him around the block and i couldn't get it to make the noise either. i think my car is messing with me. :( as soon as i dropped him off...CLICK...CLICK...CLICK. it's kinda like that dead frog that dances and sings only for porky pig. and it drives him insane. but anyway. it has been getting louder. sounds like something is gonna fall off my car when i brake. :(
IanL
Post by IanL »
Doesn't happen with the mechanic in the car. Could it be the passenger seat ?
BATTOSAI
Post by BATTOSAI »
I had some braking sounds some time ago and it resulted to be that one bushing from my fron´s wheel hub has seized, and I started to eat the hub. It was real noisy!!!
European Mx3 GsRT
Zoso124
Post by Zoso124 »
Why don't you let him drive it, if he can't hear the sound. Do this, have him put it up on a rack and take a look.
Mike Evans
Gone:
lucky13
Post by lucky13 »
haha, resa your funny. The frog and Porky. I seen that one but not for a while. :D <p>Hope you get it fixed.
