Mx-3 Flywheel on Mx-6 Clutch for KLZE
i've think i've decided to get the ACT Z62-HDSS Clutch for the Mx-6 to use on my Mx-3 for the KLZE swap, but now what i want to know is that if there's any problem with the Mx-3 Flywheel matching with the Mx-6 clutch
- Custommx3
- Site Administrator
Re: Mx-3 Flywheel on Mx-6 Clutch for KLZE
I dont believe so, many Probers use mx-3 flywheels, but just have them shaved down.
May wanna ask some of the probe guys who have mx-3 flywheels. My only concern is that the 2.5L clutch MAY be a few MM bigger than the mx-3 one. But that may not matter.<p>[ June 03, 2003: Message edited by: Custommx3 ]</p>
i think david coleman has an mx-6 cluth, but he doesnt say that he uses the mx-3 or mx-6 flywheel. I read that the mx-6 clutch is 10mm larger, but noone has said what flywheel they use, i know its recommended to use the mx-3 since its lighter, and get it down to 13lbs.<p>
I was thinking (and understood) that the mx-6 Z62-HDSS clutch can handle more power than the mx-3 Z62-HDSS, so i can put more power (turbo, nos, whatever), and not need to get a racing clutch and worry about daily driving.
The flywheel and clutch fit perfectly I would recommend getting a couple pounds shaved off of the flywheel as well as getting it resurfaced. The holding power of the ACT clutch is 260 ft of torque if I remember right. Good luck.
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
2.0L sleeved gsr block, forged internals, skunk2 valvetrain, HP racing intake manifold, Holset H1 turbo, 1000cc injectors, short geared lsd transmission, 3" turboback exhaust. 20 psi
96 Integra LS DD
91 Crx Si drag car
do you talking about the mx-3 flywheel and the mx-6 clutch? I hope so..<p>That setup should work better than the mx03 ACT clutch but not be as rough as any of the racing setups right?
Alright I don't know how to make this any clearer than this:
On my car with a Millenia KLZE I have the
Z62-HDSS Mx-6 clutch you want to buy and my 1992 215mm Mx-3 flywheel that I had milled down to 13 lbs and resurfaced the clutch dropped right in; the 94+ models of the Mx-3 have a 225mm flywheel. So far(knock on wood) it drives nicely!! I have no sloppy shifts but not jerky feeling either.
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
k, so the mx-3 clutch works with the 1992 flywheel, and works nicely, just checking...the "good luck" just threw me off got me worried.<p>[ June 04, 2003: Message edited by: Nd4SpdSe ]</p>
GuidoBiRiChiNo
I have a MX-6 clutch and a K8 flywheel too, no problems encountered.
-italian lonely MX'er-
92-93 or 94-96 Flywheel?<p>[ June 05, 2003: Message edited by: Nd4SpdSe ]</p>
GuidoBiRiChiNo
As far as I know, 92-93 models have 215mm clutch and flywheel, and 94+ models have 225mm (same as MX-6).<p>I have a 92 fw and an MX-6 clutch.. the shop that did the job didn't tell me anything about putting them together.
where did you guys who have the mx-6 clutch pick yours up at? Was it at corksports or some other vendor and how much? I'm just want to make sure i get the best price thats all.
1993 GSR - Black with CS Mazdaspeed style front and sides skirts, KLDE and a bunch of other mods. Patiently awaiting a T3Super60, intercooler,MSnS and a custom fuel rail.
1993 VW Corrado SLC- completely stock. (May she R.I.P)
im ordering mine locally
OsoSlo z28
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by mxer4eva:
where did you guys who have the mx-6 clutch pick yours up at? Was it at corksports or some other vendor and how much? I'm just want to make sure i get the best price thats all.<hr></blockquote><p>www.advancedclutch.com
www.groupbuycenter.com
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
Sean Mandell
honestly, If you want to turbo your mx-3ze then you can throw that daily driver idea out the window. go with the stage 1 clutchmasters for better pedal feel and daily driving.
"A hero and a coward both feel fear but it is the hero who reacts first while the coward hides behind the hero"
Turbo ZE wont happed for prolly 2 years anyway, so its no big of a deal, plus i'll have a 2nd vehicle next year anyway.<p>But what makes a Turbo ZE different for daily driving over a stock turbo car?<p>[ June 08, 2003: Message edited by: Nd4SpdSe ]</p>
