engine bore
plasticsurgerydisaster
engine bore
Post by plasticsurgerydisaster »
sorry if this has been asked before, how many litres can you get out of the k8 1.8 litre engine when bored 100 over
ohhhh, burn
Zoso124
Re: engine bore
Post by Zoso124 »
There is no "number" or size anyone can tell you because not many have tried. (much easier and cheaper to just use a 2.5L block) Your best bet is to show you block to your local engine builder and get his idea. If you go bigger then an available oversized piston (IIRC .040) your next problem is to find a piston that you can use, if you go with a custom piston your looking anywhere from $550-600.
Mike Evans
Gone:
pelado
Re: engine bore
Post by pelado »
FYI: (stroke x area of bore) x number of cylinders
Area of bore = pi x radius squared<p>75 x 69.6 mm is the bore and stroke of the 1.8
mm x .03937 = inches
mrspanky79
Re: engine bore
Post by mrspanky79 »
can the math expert show me how to figure it out i cant seem to get it to work. and what is pi?
Lets say i have a 75mm bore and a 74.2mm stroke.
War does not determine who is right, war determine who is left!
94 mx3 GSX Stroked Turbo'd and Intercooled
99 vitara 4x4
SimonPK
Re: engine bore
Post by SimonPK »
pi = 3.142<p>so cc's = stroke X 3.142 x bore x bore / 4<p>so using your numbers of 75mm for the bore and 74.2 for the stroke you get:<p>cc's = 7.5 x 3.142 x 7.42 x 7.42 /4<p>= 325 per cylinder<p>or 1946 cc's or 1.946 liters for the whole V6
mattster
Re: engine bore
Post by mattster »
whats pi? :eek: have you ever taken a math class in your life? j/k
92 Mazda MX-3 GS: blaze red, bone stock, and daily driver
86 RX-7 GXL: '94 LT1 V8, 6 speed tranny, scary fast. SOLD
93 Mazda RX7 R1 LS1/6speed... 75% complete
http://www.cardomain.com/id/mattsterrx7" onclick="window.open(this.href);return false;
^link to my V8 swap page
mrspanky79
Re: engine bore
when he said pi i was trying to think what messurement in the engine that pi would stand for not the math equation pie.
99 vitara 4x4
Hy300
Re: engine bore
Post by Hy300 »
Basically if you bored the K8 100 over then you would end up with a KF, but spend more money for it.
pelado
Re: engine bore
Post by pelado »
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by mrspanky79:
when he said pi i was trying to think what messurement in the engine that pi would stand for not the math equation pie.<hr></blockquote><p>Pie are round, cornbread are square. <p>Makes more sense if you're from the south and it's spoken and not read.
