1.8VAF has 5 wires coming out of it<p>
2.5VAF has 3 wires coming out of it...<p>whats the difference? and what wires to what?
2.5 VAF and 1.8 VAF
2.5 VAF and 1.8 VAF
In
Eunos 30x, v6
KL-ZE, 2.5in exhaust, K&N intake
Unichip, LSD, 13lb flywheel, ACT2 clutch, NGK iridium Plugs, Top Gun Leads...<p>Goin In
Cams, Headers, TB, Extractors,
Bored to 2.8, Mazdaspeed Struts, Mazdaspeed strut tops,
Mazdaspeed swaybars, Eibach springs, Cusco Adj. Strut tops, Body kit, Altezza lights, Short shifter, Crossdrilled rotors and Calipers from AP racing, Braided brake lines, Braided clutch line, Mazdaspeed steering wheel, Mazdaspeed Leather shift knob,
Eunos 30x, v6
Re: 2.5 VAF and 1.8 VAF
huh?
they both fit on using the harness....<p>didn't you keep the harness?
Tom Alexander
ya i got the harness,
the difference being one is a
different VAF type then the other
ones got the movable cone in the middle that
opens when it needs air the other is
always open and has a hot air needle that
sits in the tube. both are different.
In
Eunos 30x, v6
Eunos 30x, v6
The cone one is a VAF the other one is a MAF.
You can just call me the originator
ah ok <p>so he actually gave me a ZE maf...
hmmmm
well i need the VAF so i guess im gonna have to
go back and get the proper one.... although
from what i see and can tell the VAF for the 1.8 and ZE are the same in everyway including parts #s.
hmmmm
In
Eunos 30x, v6
Eunos 30x, v6
the 1.8 VAF and the 2.5 VAF are both the same.. part number JE50 from memory.. if your engine came with a MAF, then the ECU you are using controls a MAF and will have a sh*t of a time controlling a VAF.. unless of course you are using your 1.8 ECU??<p>@ds
- EUNOS 30X -
