whereabouts?
whereabouts?
I know you might think this a stupid question but where the hell is the oil filter on the 1.8 V6????
'92 MX3 1.8 V6
G-MAX 40mm lowering springs
'91 AZ3 1.5 35mm drop +V6 stryt brace.
Re: whereabouts?
Hint: try opening the hood first, it helps to shed a little light on the subject.
<p>It's on the engine block side that is closest to the radiator (the radiator is on the front of the car). It's just below the alternator and beside the A/C compressor (if you have one). It's easier to remove this part from below.
