KLZE INTAKE MANIFOLD
i hear that you cannot use the klze intake manifold when you swap it??? is there two kinds of klze's??? on that you can use the intake manifold and one where you cannot???? i heard that somewhere also... THANK YOU
Turbo 2.5l mx3
- Buff1110
Re: KLZE INTAKE MANIFOLD
klze is found in the mx6 and also the millenia.
the mx6 one has a straight neck like that of a probe gt (kl03), the millenia one (ms8)has a curved neck like whats found under our hood.
Dan
92 Mx-3 Gs, KLZE Powered!! - SOLD!!!!
02 Tacoma TRD - Daily
93 Honda del Sol - New Project
- Buff1110
i forgot to say if u end up with a klze with the straight neck manifold u can either use ur k8 one (loss of hp) or get the manifold off of a 97 millenia.
Dan
what happens when you try yo use the Mx6 manifold? Too High, Too long?
thanks i think i got lucky and got the curved neck, i'm pretty sure i herad him say that.
Turbo 2.5l mx3
Mx-6 has a neck that is too long the curved neck manifold is the same thing as an American millenia manifold.
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
2.0L sleeved gsr block, forged internals, skunk2 valvetrain, HP racing intake manifold, Holset H1 turbo, 1000cc injectors, short geared lsd transmission, 3" turboback exhaust. 20 psi![Smile :)](./images/smilies/icon_smile.gif)
96 Integra LS DD
91 Crx Si drag car
some places will cut and weld your mx6 kl-ze intake manifold to make it fit it works but not recommended
