Manifold Absolute Pressure/Barometric Pressure Circuit
This is the code readout i get on my 1.8l V6<P>P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction <P>Apparently this doesnt exist on these engines? Can someone tell me what this error is and what sensor it leads to?<P>dean.zarrillo@mts.net
David Coleman
Re: Manifold Absolute Pressure/Barometric Pressure Circuit
You'll note in the F2 chapter of the shop manual that it says to replace the ECU if you get this code...
David Coleman
CRAP!! Where does it say that? and can you please explain a little more as to why this is happening.<BR>Thank you.
The shop manual says replace ECU when u get code 14( bar. pressure .... )<BR>i get code p0105, which isnt 14, but is : Manifold absolute pressure/ barometric pressure ciruit malfuntion.<P>Im totally lost!
ANY one?? Help?
