Rad drain plug
Rad drain plug
Has anyone had trouble getting the drain plug out of the radiator? It's really stupid that they used plastic for it, it is on the front of the passenger side right? Any way to flush it without getting it out?
Re: Rad drain plug
pull off the water inlet cap, then just pull the lines on the oil filter, thats what i did
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
2.0L sleeved gsr block, forged internals, skunk2 valvetrain, HP racing intake manifold, Holset H1 turbo, 1000cc injectors, short geared lsd transmission, 3" turboback exhaust. 20 psi
96 Integra LS DD
91 Crx Si drag car
