help!
lazzyie
help!
Post by lazzyie »
well my ze runs and it idles fine too but its leaking ps fluid like a biatch now, also there is coolant leakage from the bottle on the driver side right after the fans, is that replaceable or do i have to scrap the radiator? thanks guys
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
2.0L sleeved gsr block, forged internals, skunk2 valvetrain, HP racing intake manifold, Holset H1 turbo, 1000cc injectors, short geared lsd transmission, 3" turboback exhaust. 20 psi :)
pelado
Re: help!
Post by pelado »
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by lazzyie:<BR><STRONG>well my ze runs and it idles fine too but its leaking ps fluid like a biatch now, also there is coolant leakage from the bottle on the driver side right after the fans, is that replaceable or do i have to scrap the radiator? thanks guys</STRONG><HR></BLOCKQUOTE><P>Well, your ZE won't leak PS fluid but it does sound like something is amiss.<P>Are you talking about the overflow tank or the small black tank with the pressure cap on it?
lazzyie
Re: help!
Post by lazzyie »
small black tank with other cap, ps steering hose replaced no leaks
96 Integra LS DD
91 Crx Si drag car
pelado
Re: help!
Post by pelado »
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by lazzyie:<BR><STRONG>small black tank with other cap, ps steering hose replaced no leaks</STRONG><HR></BLOCKQUOTE><P>The small black tank can be replaced independently of the radiator although it's easier to pull the radiator with the tank out. The small black tank is connected to the radiator via hoses.
lazzyie
Re: help!
Post by lazzyie »
the cap wasnt tight, duh :roll: iamsmart!
96 Integra LS DD
91 Crx Si drag car
92mx-3rs
Re: help!
Post by 92mx-3rs »
just wanted to know where i can get the 2 hoses that connects the small black tank to the radiator? been to most auto parts stores but they said they don't have it...also been to junkyard and no luck...any ideas?
supercharge or turbocharge?
