what problems if no spacer betw. TB and manifold?
what kind of engine running probs would i have? i ran it without for a while,(not driving) while down time, i was working on the engine...i put it back on recently and the idle is soo much better, would it cause throttle response probs? running probs?<P>is there any known fix to the disty prob? i had the car in downtime for about 3 months put it all back togather and now, all of a sudden it cuts out...i took the disty apart and cleaned itr all up with no luck whats up??????????????
92 GS Black (retired to wife control, but in my care)<BR>01 Focus Zx3 Black<BR>I'm Still Stationed In AR...Help???
Re: what problems if no spacer betw. TB and manifold?
first, check all the vacuum lines<BR>then make sure the intake is tied up good,<BR>then try to adjust idle <BR>that might help, if you haven't already done all that [img]shrug.gif"%20border="0[/img]
Check out my ride and leave some feedback please!
http://www.cardomain.com/id/mradio007
would it have any affects on driving? noticible?
