Big Question About Firing Order
I have a big question maybe someone has seen. I have looked in the chilton manual and on g 029 of this website manual and they both say this is the firing order. <BR>top<BR>6,4,5<BR>1,2,3<BR>But on my distributor its totaly different and I have it different. Should I change it to the way the manual reads. Is anyone else seeing the same thing. This is how my distributor reads.<BR>top<BR>4,5,3<BR>6,1,2<BR>1.8 k8 fact specs<BR>
- Zoso124
Re: Big Question About Firing Order
With out a doubt in my mind the correct firing order is, from standing in front of the car.<BR>1 3 5<BR>2 4 6
Mike Evans
Gone:
Gone:
The disty has numbers on it right?<BR>Use those.<P>And Mike listed the correct cylinder numbers above. The firing order last time i checked was 1,2,3,4,5,6. [img]shrug.gif"%20border="0[/img]
David Coleman
Dave, what does that "search" item do on this board under the "POST NEW TOPIC" item?
are those the same on the kld>??
Black-93 mx-3 Gs-R<BR>with goodies
<BR>Hondas suck, and yes i race them...<BR>oops i mean no no i dont
its really hard to find stuff sometimes ya gaypelado wrote:Dave, what does that "search" item do on this board under the "POST NEW TOPIC" item?
CF Hood, Kenwood everything, 2.25 catback exhaust, H&R Springs, F&B Strut bars
My worklog: http://mx-3.com/phpBB3/viewtopic.php?f=46&t=68856" onclick="window.open(this.href);return false;
Good afternoon from the biggest Douch around;D
did you really bring back a topic from TWO THOUSAND EFFING ONE?
yeah. you guys get butthurt if i start a new topic but i figured out my firing order so i just typed that.
