MX6 to MX3 brake swap?
Ok, I've searched the archives and found nothing on this issue.<P>Has anyone investigated the feasibility of swapping 93 or later MX-6/626/ProbeGT brakes to an MX-3? <P>I know the 6'ers are 5 lugs vs. 4 for the 3. Just checking to see if anyone with easy access to a junk yard has measured the MX-3 for this fit.
Re: MX6 to MX3 brake swap?
I'm pretty sure that they fit
What's wrong with the mx-3 brakes? Do you have 4wheel ABS?? I love mine...my 626's brakes suck
he was asking about an mx6... not a 626
<A HREF="http://www.hondaswap.com" TARGET=_blank>hondaswap.com</A>
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by pelado:<BR><STRONG>Has anyone investigated the feasibility of swapping 93 or later MX-6/626/ProbeGT brakes to an MX-3? <BR></STRONG><HR></BLOCKQUOTE><P>Did he?<p>[ November 13, 2001: Message edited by: Bri94GS ]
I believe MX-6 brakes are bigger, both front and rear. Also the later MX-6 16" wheels would then work, making for a relatively cheap larger wheel swap.
