brake pads
larz13
brake pads
Post by larz13 »
How do you take the pressure off the brake pads. I pried on the cylinder but it doesn't stay. Any tricks to this.<P>Thanks<BR>Larz
spawn_46375
Re: brake pads
Post by spawn_46375 »
are you trying to push the caliper piston back inside?<BR>if so try taking off the brake fill cover and push it in very slowly too fast and fluid will shoot out the top all over everything <P>------------------<BR>92 MX-3 GS<BR>brillant biege<BR> spawn_46375@yahoo.com
endocyc
Re: brake pads
Post by endocyc »
Yes listen to to that last reply the rear pistons must rotate in a clockwise maner to contract.
larz13
Re: brake pads
Post by larz13 »
yeah I figured it out. You guys are right you have to the piston in. <P>Thanks<BR>Larz
