'91 ECU wiring diagram wanted
joshuaj
Post by joshuaj »
Hey all<P>I am looking for a wiring diagram my ECU (91 model), specifically the PRC solenoid wire. I have tried the wiring diagram on the mx-3.com however this does not seem correct as the pin that it indicates is empty on my car. Any help would be appreciated<P>Joshuaj
white fish
Re: '91 ECU wiring diagram wanted
Post by white fish »
91? Image
joshuaj
Post by joshuaj »
Yes indeed.<BR>Imported from japan. it is the only one here in New Zealand that I have seen with the MX3 badges. All others have Presso. But yes my registration says 1991. <BR>josh
joshuaj
Post by joshuaj »
Cheeers for that jeff<P>And here is the latest. I did some hunting in my engine bay and found the PRC system. It seems that it is not controlled by the computer at all but rather the vacuum is supplied by a line running directly from the intake manifold. <P>Guess that rules our my chances of making a semi permanent modification. Oh well. <BR>Back to the drawing board looking for more mods. <P>JoshuaJ
