keyless entry needs power door lock?
This might be damn question, but I guess someone can answer this. I have RS and it has manual door lock on it. I want to have keyless entry system installed and wonder if I have to have the power door lock or not. If someone can answer, please explain that to me. Thanks.
bungo
bungo
Re: keyless entry needs power door lock?
No you do not need power door locks to have keyless entry. I don't have power locks on my GS but I have actuators installed so that I can have keyless entry with my alarm. Love not having to unlock my car with a key ![Smile :)](./images/smilies/icon_smile.gif)
Thanks for your reply. I have one more quick question. With the keyless entry or something, it automatically locks the door once the engine starts or the speed exceeds like 10 mph. With that feature, do you think I need a power door lock?
bungo
bungo
Your car doesnt need to have power door locks factory installed, you can have actuators installed. thats the only way you can have your doors lock/unlock without you doing it manually
There are a few kits floating around on ebay
Black 94 RS, Erebuni MS style front, OEM sideskirts, Clear signals, altezza tails, 93 seats, Civic projectors
I installed keyless on mine, I actually used electric locks and windows.
Ferg
i got a question.. i just bought an 93 mx3 and it comes with a remote starter and i think a keyless entry. well i think it has a keyless cuz the remote got a botton for the lock,unlock and trunk. but when i press the bottons it doesnt lock or unlock, the only thing that happens is when i press it it only makes the signal lights flash. i dont know if its not hook up rite or wat. does anyone have an idea wats wrong wid it? ![:confused:](//cdn.jsdelivr.net/gh/twitter/twemoji@latest/assets/svg/1f615.svg)
- MX3-Freak
Check you actuator connection to the brain of the system first. Then check the condition of both your actuators by taking the interior door panel off. Make sure everything is free and working easy.
Stock 1995 RS - Creek Blue
Car Meanins:
Car Meanins:
- papa roached
cany anyone suggest a decent keyless entry kit that wont break the bank?
I doubt you have actuators. I bet he just installed an alarm w/out keyless entry. Actuators are cheap if you want to add this option.Originally posted by duo-mx3:
i got a question.. i just bought an 93 mx3 and it comes with a remote starter and i think a keyless entry. well i think it has a keyless cuz the remote got a botton for the lock,unlock and trunk. but when i press the bottons it doesnt lock or unlock, the only thing that happens is when i press it it only makes the signal lights flash. i dont know if its not hook up rite or wat. does anyone have an idea wats wrong wid it?![]()
FOR SALE, AS A PARTS CAR
1994 Mazda MX-3 <-- 152dB's w/ 1 15
> Invited to '02 USACi World Finals, but did not compete due to stock alternator problems.
> Can't go to '03 USACi World Finals because I HAVE NOTHING LEFT!!
no i dont think i have alarm on it.
<small>[ June 02, 2004, 10:12 AM: Message edited by: duo-mx3 ]</small>
Regardless if it's just remote entry or an alarm, you need to add a power lock actuator on the driver's door to get it to work.Originally posted by duo-mx3:
