MX-3 has two dins for stereo and I wonder if anyone ever tried to install double din decks like sony wx4500d. I installed single din cd-player before, but I never tried to take off the over plastic piece on the other din. Please let me know.
bungo
Double Din Decks
Re: Double Din Decks
I've never done it but the plastic piece has the same bolt pattern. Just take it out and install.
you should have no trouble
Peace; Gary
Peace; Gary
- monty73741
those double din radio looks so bulky
Jason Danaher
Please Help Support MX-3.com
- Flashpoint2
Lol you can install a Double Din deck with no problems. I've got the stock tape deck in the car, and in the other slot where the pocket used to be is my CD player.
1996 MX-3 RS - Sold.
2004 RX-8 GS - Yay!
2004 RX-8 GS - Yay!
i was thinkin the same thing. use my stock as a tuner, and the second DIN for my cd/mp3/cdrOriginally posted by Flashpoint2:
*note i will not be doing the rx7 hatch conversion, id rather get a BP*
- papa roached
i had a double din in my white car when i baught it
