Rattle Reduction?!
Pope52
Rattle Reduction?!
Hey all,<p>I was wonderin if anyone has had a problem with the hatch garnish rattling like a mother...if so, and if you figured out some way to fix or reduce it..how?! Thanks guys.
lakersfan1
Re: Rattle Reduction?!
Depends on HOW it's ratling. <p>Is the hatch rattling becuase it's not snug against the weather stripping? Then you can adjust the latch so the hatch closes tighter.<p>Is trim ratling agains the hatch? If so, then just stick some foam between the two where they are making contact.<p>Is a trim panel rattling all by itself? Then apply some Dynamat to the backside.
Remove all of the plastic
Then work from there, testing with each individual piece untill it stops rattling.
I siliconed all of the plugs in the hatch to start with. I havnt had time to start placing plastic back in due to school and work
96' Blaze Red
Kicker CVR 12"
PG 250.2
JVC kx980
PG QX 1.0
Kicker CVR 12"
PG 250.2
JVC kx980
PG QX 1.0
boom, did you do a BP swap?
