Gurus i need your help- laptop install
What i want to do is install monitors in my headrests, then run the wiring to the front of the car where i can plug my laptop in allowing the monitors to display whats on my dvd drive. My laptop does not have a tv card. Is there anyway to set this up without having to buy one?
Shaun Newman
- monty73741
Re: Gurus i need your help- laptop install
hmm..........there are some types of converters but i hear they are a pain in the azz b/c they are not supported well........
best bet would be get an older del off of ebay.......then use that
Jason Danaher
Please Help Support MX-3.com
Generally laptops (at least newer ones) have a video output port so that you can hook your laptop up to a regular monitor. It would take a standard 15 pin monitor cable. I'd check around, out there somewhere is some sort of "adaptor" cable that would have 15 pin male side to go into the laptop and rca on the other side to go into a tv (or receiver, vcr, etc...).
Steve
Steve
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by sheller:
I'd check around, out there somewhere is some sort of "adaptor" cable that would have 15 pin male side to go into the laptop and rca on the other side to go into a tv (or receiver, vcr, etc...). <hr></blockquote><p>There no adaptor, what you need is a scan converter. Its a unit that takes VGA and converts it to S-Video and RCA<p>
Here are 2 examples we can get:
http://startech.com/ststore/itemdetail.cfm?ProductID=VGA2NTSC&topbar=topbara.htm<p>http://startech.com/ststore/itemdetail.cfm?ProductID=VGA2NTSCPRO&topbar=topbara.htm
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Nd4SpdSe:
http://startech.com/ststore/itemdetail.cfm?ProductID=VGA2NTSC&topbar=topbara.htm<p>http://startech.com/ststore/itemdetail.cfm?ProductID=VGA2NTSCPRO&topbar=topbara.htm[/ QB]<hr></blockquote><p>
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by monty73741:
[QB]hmm..........there are some types of converters but i hear they are a pain in the azz b/c they are not supported well........<hr></blockquote><p>i dont know where you heard that, but i doubt its true, there is no softwre involved and its easy as pie to use. Plug-in and go. Some will even allow to center teh display on the tv
- monty73741
i mean the scan converter.......software inside is usually not supported by the company that makes em(at least the cheap ones)....since most new video cards have video out......all you need to do is hook it up to a tv/monitor.......also the scan converters are a pain to get working.......
Jason Danaher
i've never encountered one what was plug in and go, and the good ones dont have software, like this once i've tested:<p>http://startech.com/ststore/itemdetail.cfm?ProductID=VGA2NTSCPRO&topbar=topbara.htm<p>it had buttons on the top for adjusting and thats it. Even my old one that does only 640x480 doesnt need software to run, it has software which i lost, guess its for display adjustments/centering, but it works no problem withough it,just plug in and go...<p>Unless your a dumbass, you can not not get it working, unless your running at a resolution/refresh rate that it cant handle, but thats your fault, not the device, normally its just pulg in and go
