prm install ?
prm install ?
I just got a prm intake and the only problem i have run into is the brass nipple for the vacume line that comes with the sylicon spacer. the problem is that i don't have a vacume line to hook up to it is my car missing one or is thern not one for it i have a 92 gs
Re: prm install ?
the vacuum line, is the one that you took of the stock air box before you tried to install it. If you check my website I have some better instructions for installing the prm intake, the ones they came with are next to garbage.
Tom Alexander
- monty73741
Re: prm install ?
DIDNT THINK THAT THE GS AD A VACCUM LINE THOUGHT IT WAS ONLY THE RS
JASON
JASON
Jason Danaher
Please Help Support MX-3.com
Re: prm install ?
the vac. line makes no difference anyway... Dont worry about it
Shaun Newman
Re: prm install ?
I dunno, if I take the vaccuum line off it will sometimes make the idle fluxuate a few hundred rpms...
Tom Alexander
Re: prm install ?
there is a vacuum line found on the GS and i seemed to have noticed the difference when it wasn't connected because my idle would drop too low sometimes, and when i put it back on it was ok... maybe just a coincidence
92 Mazda MX-3 GS: blaze red, bone stock, and daily driver
86 RX-7 GXL: '94 LT1 V8, 6 speed tranny, scary fast. SOLD
93 Mazda RX7 R1 LS1/6speed... 75% complete
http://www.cardomain.com/id/mattsterrx7" onclick="window.open(this.href);return false;
^link to my V8 swap page
Re: prm install ?
well the mean problem is that i didn't have to take a vacume line off my old intake and i don't see one just lying around so were does the other end of the vacume line attache to.<p>[ December 30, 2002: Message edited by: Mx-3SHO ]</p>
