Wheel Sizes
Jimbo1177
Wheel Sizes
Post by Jimbo1177 »
Does anyone know the width of the standard GS wheels? Are they 6 or 6.5 inches?
And can someone confirm, the offset of the standard wheel is +45, correct?
The reason I ask is I'm looking at a set of wheels that are 15x6.5 +32. My understanding is the +32 will essentially push the barrels of the wheel a bit wider since the hub is a little closer to center. Anyone have experience running wheels with that offset?
Jimbo1177
Re: Wheel Sizes
Post by Jimbo1177 »
Found the answer I was looking for in the technical manuals. Figured I'd post it here.
B6 cars:
14x5.5 +45
4x100 bolt pattern
Tire size: 185/65R14
K8 cars:
15x6 +45
4X100
205/55R15
lewismak
Re: Wheel Sizes
Post by lewismak »
Bump. So did you get those wheels? Just curious here if they fit ok.
Demonic1
Re: Wheel Sizes
Post by Demonic1 »
Those are stock sizes lewis. They will fit fine.
92 RS BP05
93 GS KLZE
lewismak
Re: Wheel Sizes
Post by lewismak »
Thanks demonic1 for replying. I ordered a set of Konig Helium's at car|truck wheels - 4wheelonline.com. They are 15x6.5 +40. What do you think is the perfect tire size?
