How do I replace power window switches with 2-5 pin switches
Posted: May 27th, 2014, 7:57 pm
Hello:
I am new here and should have joined a long time ago. I have a '95 mx-3 and have replaced the entire power window switch mechanism 3 times. Very frustrating and very expensive. I thought possibly I could buy 2 - 5 pin rocker switches to replace them both. I was in a situation where the driver's side window stuck half-way up and I had to take the panel off (again) and was able to find the two wires that would make the window go up. Now I'm driving with both windows up because there is no choice. The passenger side decided to stop working also. If I bought the 2 - 5 pin switches could someone tell me which wires go where? I will figure out how and where to place them but I just want to bypass the whole thing if I can. This has been one of the best cars I have ever owned. It has 115,000 miles on it and I'm sure it will go another hundred thousand. It has been my experience that this is the only defect in the entire car.
Any help is greatly appreciated.
Thank you,
Silver
Thank you,
Silver
