control arm ball joint
anyone has had a problem with those? both of mine are gone (ball joint dust boot is gone),it's all cracked up; and the car drives terrible over speed bumps and cracks in the road. Here is the question: do I have to change the whole ball joint , or I can just change that dust boot?<BR>anyone has any input on this?
Check out my ride and leave some feedback please!
http://www.cardomain.com/id/mradio007
Re: control arm ball joint
Change the whole joint.
David Coleman
do you have any idea how much they cost?
I think I have the same problem, can you describe the noise a little bit more. <BR>mice sounds like a ball joint also. but it's mostly audible at low speeds? I wonder!!!!
92 mx-3 GS .greeeeeeeen!<BR>Honda !!!, what do you mean Honda??<BR>Oh sorry, you meant that piece of crap parked next to my car! oh sorry again, I meant to say lawnmower....
if i go over speed bump real slow I can't hear it, but when I drive over any bump at speeds above 5mph I can hear pounding noise, like 2 pieces of metal hit each other, plus when I corner and drive over a bump I can feel the front chassis shift a little. It's had to explain, this is the best I can do.
