Page 1 of 3
1" or bigger Master Cylinder?
Posted: October 10th, 2013, 8:50 pm
by gerald_23
I'm looking to do a full on brake upgrade over the winter and I would like to look into a new master cylinder. The Mx-6 Master Cylinder looks longer but the diameter is the same. Does anyone know of any other options?
Re: 1" or bigger Master Cylinder?
Posted: October 10th, 2013, 9:31 pm
by mitmaks
Millenia master cylinder is bigger.
Posted: October 11th, 2013, 12:29 am
by wytbishop
The Millenia master has a 1" piston, but the ports are on the other side and the length of the push rod and stuff are different. I have been planning on making it work when I do the refurb on the Black Beast, but it's not plug and play at all.
Posted: October 11th, 2013, 12:51 am
by mitmaks
You will have to rebend your brake lines so they would bolt up on the other side of master cylinder.
Posted: October 11th, 2013, 7:39 am
by Sleeper6
Ive heard rumors of using 929 parts, might be worth some research
**edit with a quick search:
http://mx-3.com/phpBB3/viewtopic.php?f= ... &hilit=929
Posted: October 13th, 2013, 11:32 am
by gerald_23
Thanks for the information everyone
Posted: October 15th, 2013, 12:16 pm
by Josh
929 1" master on an RS booster will work. should be plug and play.
I am with Wytbishop on my milly 1" master convo on the GS. I have not played with it enough yet to install it, but have noticed the reservoir will need to be swapped to the GS one also, as it sits at a funny angle in the milly.
Posted: October 19th, 2013, 2:57 am
by [LVPA]93GsSe
I installed the milli master. It is a bit of a pain tho. You reuse the old reservoir. You have to trim some of the housing from one of the sides to fit the mounting bolt. Take the banjo fittings off, bend the lines(carefully) to the other side of the master and screw the lines in directly. That's pretty much it. Now that I read what I wrote down, it doesn't seem very complicated, LOL.
Posted: January 5th, 2014, 3:31 pm
by gerald_23
Sorry about the late reply but thank you everyone for you input. this among other things will be getting done soon and i will make a write-up for it.
Posted: January 5th, 2014, 3:58 pm
by WhiteFinish
[LVPA]93GsSe wrote:I installed the milli master. It is a bit of a pain tho. You reuse the old reservoir. You have to trim some of the housing from one of the sides to fit the mounting bolt. Take the banjo fittings off, bend the lines(carefully) to the other side of the master and screw the lines in directly. That's pretty much it. Now that I read what I wrote down, it doesn't seem very complicated, LOL.
Please share with some pics
Posted: January 6th, 2014, 8:19 pm
by gerald_23
absolutely
Posted: January 6th, 2014, 10:43 pm
by [LVPA]93GsSe
Ok, will do give me a cpl days, it's pretty cold and windy around here the last few days...
Posted: January 12th, 2014, 4:09 pm
by WhiteFinish
[LVPA]93GsSe wrote:Ok, will do give me a cpl days, it's pretty cold and windy around here the last few days...
Did you have a chance to take some pictures.
Posted: January 12th, 2014, 9:44 pm
by [LVPA]93GsSe
Okay, I finally got to them, while trying to figure out why shes not starting....
Here is the lines re-routed to the other side, I shoulda got a picture of more of the line, but all I did was carefully bend them.
Here is the pass. side area where I cut.
And the drivers side.
![Image](http://i800.photobucket.com/albums/yy290/jeremy_jackson4/a6385f2b-9c67-4616-bfbb-6b6f670f255e_zpsc2b491f4.jpg)
Posted: January 12th, 2014, 9:48 pm
by [LVPA]93GsSe
Okay, I didn't cut the drivers side, but from them the pic it looks like I did. I thought I did for a sec.
