Noise when taking off
- mitmaks
So if Im stopped at the light and I try to take off, as I release clutch pedal there's clunking noise. It only happens when Im releasing clutch in 1st gear from take off, doesn't happen when Im shifting in other gears.
							Magnum s/s lines, strut bars, carbon fiber bezel, indiglow gauge, Sony Xplod, inverted c/f hood, SRD lower tie bar '93 GS SE  '95 Cobra SVT #2722 '68 Charger R/T 440
				RobMinhas
Re: Noise when taking off
Does it maybe happen on hard braking?  Could be a motor mount.
- mitmaks
Nope, almost sounds like cv joint but it only does it when taking off in first gear. I think it might be clutch related but not 100% positive.
- Ryan
What if you go on and off power in 1st?
I had some ultra worn out LCA bushings that were clunking around in the housing... they'd only clunk when the direction of force changed (from brake/engine brake to accel)
- MrMazda92
Try to very carefully start in second, and see if the clunking continues.
I have the same issue but mine will also do it when simply accelerating in any gear. Going to check a few things out soon. Let us know if you solve it!
							1995 Eunos 30x KLZE
- mitmaks
I just had alignment done. Prior to that I;ve replaced ball joints, tie rods and struts all around. Car handles like new except for that strange clunk in first gear.
- [LVPA]93GsSe
If you have a v6 check your mid shaft axle bracket (that attaches to the back of the block), I had this same problem and found that my brackets bolts all loosened up and fell out on me, in fact, it did it again just recently. Thanks for reminding me I had forgetten.
							Knowing you've spent too much on your car,
yet, you still want to keep modding. -priceless
boosted_bullet
93 Honda Accord LX - Wrecked
95 Honda Del Sol Si - Stolen
92 Honda Accord EX - Parted out
2000 Toyota Celica GTS - Cracked block and broken differential teeth
93 SE - ATX to MTX, work as always in progress
01 Toyota Celica GTS - DD
Worklog to be up soon, still... ...
boosted_bullet
- mitmaks
it only does it when taking off in 1st gear.
The mid shaft bolts are known to be a problem. The engine block corrodes along the length of the bolts holes and eventually the bolt won't tighten. The holes are blind thread so go with a bottoming tap for sure. I reamed mine out and went to a 7/16 bolt (next size up).[LVPA]93GsSe wrote:If you have a v6 check your mid shaft axle bracket (that attaches to the back of the block), I had this same problem and found that my brackets bolts all loosened up and fell out on me, in fact, it did it again just recently. Thanks for reminding me I had forgetten.
Have you tried jacking the front end and turning the wheels by hand? When starting off can you feel the clunking anywhere, hands, clutch foot?
- mitmaks
It seems like it's coming from suspension (drivers side)
Screw it, just replace the axle assembly.  If it still clunks get a second job, your going to need it.  mwahaha.
- mitmaks
axles are new so is rest of the suspension.Daninski wrote:Screw it, just replace the axle assembly. If it still clunks get a second job, your going to need it. mwahaha.
- mitmaks
Ive decided to take a better look at it past weekend. Took wheels off and inspected all the suspension parts and everything looked good. I installed wheels and instead of torquing them to 75ft/lbs like I usually do I went to 80ft/lbs and now mysterious noise is gone.
- stereoking15
Oddly enough I have the same exact issue. A clunk when taking off and never notice it any time after that as well
 . I have new lower ball joints, tie rod ends (outer) lower control arm bushings. The only thing I can think of is maybe worn out upper strut mounts but those are newish (6 years old). I mostly started to notice it after I replaced the regular lower control arm bushings with urethane ones but have greased them several times since with marine grease and I don't even drive in the rain. Axle's are also newer but recently launched the passenger axle showing off
