Front strut mount
- mitmaks
Front strut mount
Eventually I will be replacing front strut mounts along with shocks. Do strut mounts come with bearing or I have to buy them separate?
- Oke
Re: Front strut mount
Hy, i am not sure but i think many do, but only when the strut mount is also the steering pivot. The bearing is a wear item and affects the steering response as well as wheel alignment.
MX3 1.8 v6 GS '93
- Evo_Spec
some do some don't, if you're picky too you can get metal ones from by ford racing for the ZX2, most come with plastic ones
