Correct TPS kohm readings?
dwh1
Post by dwh1 »
I've tested TPS's from a few different engines all coming from rs's and the highest reading I get when fully open is approximately 3.4 Kohm and .500 when completely closed on all of them. Does anyone elses TPS go higher? I ask because I obviously suspect a faulty TPS and the book states approximately 5 kohm when open and 1 kohm when closed but my "double checking" is only confusing the matter. It is possible all the engines have bad TPS's just as well as a bad print in the book. So what's yalls readings?
crazycanadian
Re: Correct TPS kohm readings?
Post by crazycanadian »
dwh1 wrote:I've tested TPS's from a few different engines all coming from rs's and the highest reading I get when fully open is approximately 3.4 Kohm and .500 when completely closed on all of them. Does anyone elses TPS go higher? I ask because I obviously suspect a faulty TPS and the book states approximately 5 kohm when open and 1 kohm when closed but my "double checking" is only confusing the matter. It is possible all the engines have bad TPS's just as well as a bad print in the book. So what's yalls readings?
ohming a TPS wont tell you if its bad or not... TPS develop flat spots that you can not see with a standard volt meter... measuring base and max ohms is an extremely ineffective test...
... 5Kohms would be a value that you might get if the TPS was off the car and you manually turned it all the way... You wont always get a full sweep while the tps is installed due to how the throttle linkages are designed..
why do you think your tps is bad???
Ryan
Post by Ryan »
also, potentiometers behave in strange ways.
I've never seen an OE TPS fail on these. I'd quit looking just on statistics.
What are the symptoms that are making you suspect TPS?
