[Problem] Steering, help?
lpeixoto
Post by lpeixoto »
Hello guys,
My hydraulic steering is making a strange noise when I turn either way, even if the car is stopped. (Tec, tec, tec) does anyone know what can be?
I wanted to bleed the fluid, does anyone know where i do that?
thank you
Demonic1
Re: [Problem] Steering, help?
Post by Demonic1 »
Actually it sounds like you may have a bearing going out. The power steering shouldn't really be making noise.
Have a friend help you, get under the hood and have them turn the wheel. Listen to where the noise is coming from.
Here's a CP post about changing the BJ power steering. More than useful, and really well written.
http://www.clubprotege.com/forum/showth ... -Change-BJ
92 RS BP05
93 GS KLZE
lpeixoto
Post by lpeixoto »
tks,,, i will try it! :)
