stock rubber intake air tube on v6
- mx3_ryder
looking to install cai and was wondering if air tube that hooks from the intake to the pcv system is necessary or if i can just cap it off or run a new hose? I know its for fresh air, or should I weld an aluminum bung on the intake? thanks
Re: stock rubber intake air tube on v6
I bought a brass fitting, drilled a hole in my CAI and installed it so I could hook up the PCV hose.
