KL-DE Swap no start
Thefez
KL-DE Swap no start
SO as some of you know i blew up the K8 and was building a KL swapped it in and now I cant get the car to start..
I have spark
I BELIVE i have fuel not 100% on this.
im using the disty out of my K8
Using a MIlly intake mani
and also useing a kl01 computer and kl02 vaf
I have codes
5,9,25,41,46 poping up as well
any ideas would be greatly apreciated
I have spark
I have codes
RobMinhas
Re: KL-DE Swap no start
Have you checked your grounds? One might be loose somewhere which could potentially cause the no spark.
Thefez
did check my grounds there pretty good, i pulled a plug and it did spark apon cranking so im assuming i have spark.. but does the disty have its own ground? small wire in the part of the harness leading to the disty plugsRobMinhas wrote:Have you checked your grounds? One might be loose somewhere which could potentially cause the no spark.
im not sure I have fuel tho..
also another question. is there any way i have have the disty out 180 degreeess? it only seems to go in one way.
RobMinhas
Oh s--- I misread that about you getting spark.
I don't think the disty has its own ground wire though.
Maybe double check for your fuel? At the very least it's one thing we can discount if it's present.
Thefez
RobMinhas wrote:Oh s--- I misread that about you getting spark.
very true im going to go swap the FPR from the K8 manifold so i know its working... and ill also be able to tell if I have fuel or not but that wont tell me if the injectors are firing or not.
RobMinhas
It could be that you've got your fuel lines mixed? s--- I can't remember which side is which after pulling an engine haha.
Thefez
ya know i should try switching the lines i didn't even think about that... would that really cause it not to start? i called in quits for the night gunna start up agien tomarro.. but i didn't get as much fuel out of the rail as i expected when i pulled it.RobMinhas wrote:It could be that you've got your fuel lines mixed? s--- I can't remember which side is which after pulling an engine haha.
Thefez
Switched the fuel lines still wont start, I did have the line backwards. Now im getting a code for the tps and bolth vris solinoids. Will the car not start with a bad tps?
RobMinhas
I don't know about the TPS problem but for the VRIS problem, are your vacuum lines plumbed correctly?
Thefez
ya im prett sure the solinoides are bad.. not 100% sure tho on that. but i only have 1 plugged in since I just wanted to get the motor broken in first befor i started making wires longer.RobMinhas wrote:I don't know about the TPS problem but for the VRIS problem, are your vacuum lines plumbed correctly?
I went out and bought a compression tester and I only have 105psi on the 3 cyl in the front of the engine? shouldn't it be more like 180-210psi? I mean this is a freash rebuild so week compression at first should be expected at first till the motor starts and the new rings car wear into the honed walls, correct?
But so far this is what we got spark, fuel, and semi low compression.
I do have a question tho I took off the front valve cover to make sure when i put the cams back in the motor that I had lined up the marks 100% and they are. The only other thing I can think of is are the cam gears interchange able? and are they suposed to be on one head or the other? could I have switched them up and not have the timing markes be where they should? So could that make the timing not where it should be?
Thefez
got the car to start this morning but died unless i give it gas, guessing i have some vacume leaks and some other things i need to work out with the car. all other updates will be posted via worklog thanks for the help
Died unless you gave it gas, hmmm. Was it misfiring? Spark plug wires are on the wrong way, massive air leak etc?
Disty can't be on the wrong way. Cam pulleys can be on backwards and still have correct markings but I am not sure about swapping the L and R camshaft pulleys.
1995 Eunos 30x KLZE
If your using the K8 ECU and your cars disty then take that KL02 off the car and put the JE50 on. The KL02 will only work with a DE harness or a 96/97 MX3, period.
With the KL02 VAF your engine will run like crap.
Edit; misread about ECU
News to me, typically that combo works fairly well.
- mikeetown
Nd4SpdSe wrote:News to me, typically that combo works fairly well.
ya i hear ya. that combo is currently working for me.
Im not sure if your egr system is working or if you have it removed, but check to make sure the port at the back of tr motor is plugged.
mikeetown
93 Black GS - J-spec KLDE, CLEAN CAR
92 Red GS - J-spec K8ZE, stripped interior - Written off
2004 Infinity G35 Track Edition - 6 speed manual
viewtopic.php?f=17&t=79142
