I couldnt find it online here. Can anyone tell me how many inch/lbs I should torque it on at?? I cant remember.
124 inch/lbs. ???
V6 oil pump torque specification?????
- mikeetown
mikeetown
93 Black GS - J-spec KLDE, CLEAN CAR
92 Red GS - J-spec K8ZE, stripped interior - Written off
2004 Infinity G35 Track Edition - 6 speed manual
viewtopic.php?f=17&t=79142
- stereoking15
Re: V6 oil pump torque specification?????
14-18 ft lbs as per alldata. 1 ft lb= 12 in lb
- mikeetown
for torquing on an oil pump to the side of the engine, that seems overly high?????
mikeetown
- stereoking15
That's little more then 1/4 turn past finger tight. Hardly anything. Its what I did with mine
