Good day!!!
I have a 92 SOHC which I love due economic reasons (gas saver). It has been consuming a lot of motor oil. About 1 quart every 400-500 miles. First thing I did was to check for leaks. There was none. Next thing I did was to check the spark plugs for signs of fouling. All four plugs are nice and dry without any signs of unusual/abmormal operation.
I am just puzzled where all the oil is going. Eversince my last oil change 4000 miles ago, I have added 7 quarts.
Any ideas?
High motor oil consumption
- kudkudniyog
Re: High motor oil consumption
You probably need to use this. http://www.kanolabs.com/ It'll free up sticky oil and compression rings.
- Evo_Spec
this is basically just seafoam right?Daninski wrote:You probably need to use this. http://www.kanolabs.com/ It'll free up sticky oil and compression rings.
- kudkudniyog
Add this to the oil? I am due for an oil change. Should I add if before or after?
- im2bad4ya
you most likely need new valve seals
-1992 MX-3 RS w/BP Swap Tropical Emerald Metallic "Lucky" 2005-2012 *REST IN PIECES*
Worklog: viewtopic.php?f=46&t=78176
-2003.5 MAZDASPEED Protege #882 Blazing Yellow Mica "Lemon Drop" 2012-2015 SOLD!
-2003 MAZDASPEED Protege #1186 Spicy Orange "Debbie" 2014-2015 SOLD!
-1980 Toyota Corolla Green 2014-present
-2002 Lexus IS 300 Solar Yellow 2015-present
- Ryan
Does it smoke more in the morning on startup or when you overrun it (WOT to 0 throttle) or under power?
If it smokes under any of those conditions it points to a specific problem.
- bbunkerc397
valve seals.
1996 MX-3 KL-ZE with Eunos 800 IM, factory side skirts,. "Owner since 2001 my 14th year"
1992 929s 20B-REW Lowered, 17" chrome Millenia rims, custom black interior. "13th Owner 9th year"
2006 Chevy HHR LT "Bought Brand New - East Side Chevy" Sold to my Dad
