My car ran out of voltage while my Dad was driving it.
I did what every person should do, and checked the voltage coming from the alternator. It was not charging, so, obviously, it was bad. I got a new one, and put it in. The new one didn't work, either. It happens. So I took it back, and had it bench tested. It was working fine. I had them do it again. It was fine.
NOW what
This is the point where every good mechanic starts desperately poking at random things in the area. I shook the wire harness. I got underneath the car, and took the belt off again. I spun the alternator pulley. With my mind wandering, I laid underneath the car. I poked the other belt. I was like an infant playing around with a mobile in a crib, pulling, and pushing things. I spun the crank pulley with 2 fingers... Wait a minute. I don't think that's right. I spun it again. It ran smooth, and quiet. The inside part stayed stationary. That definitely isn't right. I felt like one of Romney's "Smart people" when I exclaimed to myself "That's not supposed to happen!" I was sure of it; If the crank pulley spins freely, it can't turn the alternator. So there you have it. The outer part of the crank pulley had separated from the rest. I have never heard of that happening before, and I have worked on many, many cars of all types.
So, on Friday, I'm finally going to put on my underdrive pulley with Mooneggs' help.
