A/C issues
_lithium_
A/C issues
Post by _lithium_ »
Okay so I've been having issues with my A/C clutch not engaging on my 92 mx-3 GS and my brother said he changed the clutch before on it but used one from a straight 4 mx-3. It got to the point where he would have to lay down and hit it (car on and ac on) with a ratchet for it to engage but now it does nothing. What are the steps to remove this clutch and look at it? Is it pretty simple?
mitmaks
Re: A/C issues
Post by mitmaks »
Check online manual
_lithium_
Re: A/C issues
Post by _lithium_ »
It's not in there, I checked there first. I also have a Chiltons manual for my car and it's not in there as well. A lot of the information I find says something about it's not supported by self-repair manuals and is to be done by EPA certified (I think that was the name) mechanics only.
mitmaks
Re: A/C issues
Post by mitmaks »
mitmaks
Re: A/C issues
Post by mitmaks »
Personally I'd check to see if there's oil in the compressor and if it's the right oil, you don't want to mix oils. New PAG oils are backwards compatible.
