I did the automatic to 5spd swap like 4 years ago. The other day, I cleaned up some of the crappy soldering I did and forgot to keep track of some of the wires (4 of them).
I used the search feature and read the faq but could not find a answer.
This is about the big yellow connector (2x6 pins) that hooked up to automatic tranny. What is the function of each pin?
If I remember right, there are two wires that are suppose to be jumped in order to start the car. Which are they?
Which are the reverse light switch wires?
(Quick question) Automatic to 5spd wiring (not in FAQ)
Juans_93_MX3
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
Re: (Quick question) Automatic to 5spd wiring (not in FAQ)
I can't answer all your questions. I looked at my gs, atx-mtx was completed 6 years ago, and the wires to jump for the car to start aren't on the larger connector, but on the smaller, 3-prong connector.
Turn it so the connectors are horizontal, they'll be in a triangle, like this:
_-_
jump the top to the bottom left
_/- _ (crude illustration, but it works)
I never bothered getting reverse lights to work, hasn't been an issue for me.
Surely someone else can help out there...
_-_
93 GS, ATX to MTX swap, chrome 16x7, upper strut bars, SRD LCA bushings.
Upcoming improvements: Tokico/Eibach struts/springs, energy suspension LCA bushings
94 RS MTX, Engine swap completed, ALIVE Again!
95 RS ATX, parts car/project X
Juans_93_MX3
Thanks for answering.stepchyld wrote:I can't answer all your questions. I looked at my gs, atx-mtx was completed 6 years ago, and the wires to jump for the car to start aren't on the larger connector, but on the smaller, 3-prong connector.
_-_
I can help you out with that. I actually got the reverse lights wOrking. Give me a week to put everything together and I'll post pics on how to do it.
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
You're welcome.
I had the info when I was finishing the swap, but don't know where it is now. I was just excited to finish the swap and drive a GS for the first time. Figured if it became an issue, I'd dig into it.
would be nice to have the info, reverse lights are handy, and safer...
