What's with the water pumps?!
fowljesse
Post by fowljesse »
I stopped driving the stock GS because the water pump seal broke. Now the same thing happened on the fast one. Each of them had about less than 40,000 miles on new water pumps. The stock one was run without water by my ex, until it stopped. Then it ran for 2 years before the pump went out. The fast one was always taken care of.
Who else has had early water pump failures?
Is there a superior brand to buy next time?
Re: What's with the water pumps?!
My original water pump on my K8 start to go when the car had only 120'000ish KM's on it. A new aftermarket waterpump was put on when the ZE was put in, but that never went and had just over 100'000kms on it.
I've never really read anyone having abnormal failures on the waterpump
fowljesse
Post by fowljesse »
To clarify; the pump itself might be okay, but the seal is gone. When I put water in, it dumps right out from behind the timing belt cover. The same with the stock car. Maybe the pump can only take 20 lbs or so of pressure..
mitmaks
Post by mitmaks »
OEM one on my K8 failed at ~70K. Which brand are you using?
Sleeper6
Post by Sleeper6 »
Your not putting any sealant on the O-ring when you install it are you? That will cause it if you do or fail to clean out the channel it sits in. Ive had 3 now and none that have failed yet.
fowljesse
Post by fowljesse »
I have no idea which brand(s). I never buy the cheapest ones, but rarely buy the most expensive ones. I usually ask the counter guy(s) if one is better than another.
I actually don't remember if I put sealant on. I'm pretty sure I didn't, because I never do, when it has a rubber ring. That's good to know that it can make it worse, if one does. I always clean everything, and finish cleaning with rubbing alcohol, and make sure it's dry.
wagZE
Post by wagZE »
I have always used RTV gasket maker around the water pump's rubber gassket & never had any problems with them. Soemthing just makes me feel better about having extra gasket on there, I mean why not the stuff is cheap.
1 mx6 88 LX auto 2.2l 4cyl
2 mx3 93 gsze bought w/ mods
4 mx3 GS SOLD-
2 pgt primered 5 spd KL SOLD
RX8SE3P
Post by RX8SE3P »
I put sealant on mine. Pretty sure the workshop manual says to do so.
I've only done about 20,000kms so I can't give advice yet. Maybe in 3-5 years I'll let you know which brand is best LOL.
1995 Eunos 30x KLZE
mikeinaus
Post by mikeinaus »
Is it the gasket that is failing or the actual shaft seal? If its the seal there isn't much you can do other then try a new brand... I've got a cheap eBay pump on my ze, its not very old but no problems so far.. .
I'm sorry my friend but it is the 'will of Allah' nothing more. Never buy rebuilt pumps always buy new and Insha’Allah it will not happen to you again. That is the best advise I can offer you.
I will add that a pump must have lubrication either using antifreeze or some other product with equivalent lubricating abilities. Straight water is a definite no no. Demineralized water is also highly recommended in lieu of tap water. :D
fowljesse
Post by fowljesse »
Thanks, everyone. I haven't gotten into it, yet, so I don't know if it's the shaft, or the outer seal.
