Fuse question
Fuse question
In the fuse box under the hood, the one that says (AD FAN) 40A what fan does it go to? Is it normal for this fuse to pop?
1993 mx-3 gs v6 work log
viewtopic.php?t=79424
Re: Fuse question
It's not really normal for any fuse to pop, UNLESS there's a problem, then it's perfectly normal for one to pop, and possibly blow replacement fuses till the problem is found and fixed.
Manual says it's for the A/C Condenser Fan, which is the fan on the left if you're facing the engine bay.
93 GS, ATX to MTX swap, chrome 16x7, upper strut bars, SRD LCA bushings.
Upcoming improvements: Tokico/Eibach struts/springs, energy suspension LCA bushings
94 RS MTX, Engine swap completed, ALIVE Again!
95 RS ATX, parts car/project X
