KF hesitation/stumble on acceleration, PLEASE HELP ME!
JeremyP
Post by JeremyP »
Hey gang, so I was having problems with my KF. One day it randomly started after turning the car on after it had been running. The car was off for about 10 min. Upon starting it was very boggy and stumbles over itself on acceleration. We tried everything from tps, fpr, maf, fuel rail, manifold for cracks, and comp. test. All the things that you would think. So hey, why not go buy a New KF slap it in and try. First drive home, started again.. The car drove amazing for 5 months before all this. I'm running 1.8 Ecu, maf, ditsy, throttle body. And it's a 94 5 speed. Any help at this point is very much appreciated. Thanks again gang!
94' KF-ZE, 2 Tone black and gray, Projectors and altezzas ( black ), CAI, moulded mazdaspeed mini sides. Raised spoiler.
cWs306
Re: KF hesitation/stumble on acceleration, PLEASE HELP ME!
Post by cWs306 »
Ignition coil? test it with a multi meter on the 3 prong plugs outer prongs. should read 11.5-18ohms
JeremyP
Post by JeremyP »
cWs306 wrote:Ignition coil? test it with a multi meter on the 3 prong plugs outer prongs. should read 11.5-18ohms
It's the internal from the 1.8, only 6 slots On the ditsy. Does that make any difference?
cWs306
Post by cWs306 »
yah thats the distributor plug. theres the coil plug on the back side of that(looking from the front of the car). its a little lower n hidden cause its plugged into the coil.
