the white bracket in the picture is the issue... the sleeve the bolts go thru into the block require and 85-90mm long bolt. i thought i found something suitable but realized quick the thread pitch was wrong. so i shaved the sleeves down a bit but still no luck in finding a bolt, went to home depot, rona, canadian tire, brafasco and still no luck.
I believe the bolt is a m12x1.5 and it'll need to be at least 85mm long(about 3.3 inches long)
