Custom exhuast question.
Posted: March 11th, 2012, 6:07 pm
by Thefez
Hopfuly this week ill have everything needed to weld up my new custom exhaust. Im planning on using my bosal headers and y pipe to a high flow cat 14"or 18" rez to a super 44flowmaster muffler. Now my questionn is how many ft of pipe and what degree bends am i goin to need? Also its going to be a 2.25"
Re: Custom exhuast question.
Posted: March 11th, 2012, 7:20 pm
by mikeinaus
i dont think anyone is going to know that off hand. your best bet would be to cut off your old exhaust and lay it on the ground beside your new parts. you should then be able to figure out what you need.
Posted: March 11th, 2012, 7:28 pm
by Thefez
mikeinaus wrote:i dont think anyone is going to know that off hand. your best bet would be to cut off your old exhaust and lay it on the ground beside your new parts. you should then be able to figure out what you need.
I dont have a pipe bender and i dont wana go crush bent. Figered someone might know so i can prebuy the bends im goin to need. But thanks for the reply much apreciated.
Posted: March 11th, 2012, 11:57 pm
by crazycanadian
You prebuy mandrel U or J bends... Use the Dynomax ones they are aluminized and last longer then regular steal ones... part number 42394.... I know up here lordco stocks them... You cut them up and weld them together to make your system...
It'll end up looking like this...
If you are resourceful with how you do the bends, cut them up and weld them together you could probably get away with 2 - 3 U bends to make the entire system... Very rarely have I had to buy extra straight pipe...
Posted: March 16th, 2012, 6:56 pm
by MrMazda92
Bends... :( Fuel cell in the trunk anyone? :freak:
